RSTChris Posted July 6, 2007 Share Posted July 6, 2007 Hi all, basically i was woken at daft o'clock this morning to find some pikey scum inside my 300 tdi defender!! , theres no door lock damage? :huh: but the steering lock and ignition barrel are hanging off!!! Basically i need to know the way to change the lock.barrell. Ive got an older 90 td defender i can pinch the lock etc off but havnt got a clue where to start Any help, guides or tips greatly appreciated Thanks Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 6, 2007 Share Posted July 6, 2007 The ignition/steering lock is held to the steering column by security bolts - when they are tightened the bolt head snaps off so that they can't in theory be undone. But with the use of a centre punch or similar the bolt can still be undone, it just takes a bit of patience. The ignition barrel will then just come off, even if the steering lock is still on. I don'r know if a defender one will fit, but you can either buy the security bolts from the usual suppliers or use a couple of 20mm M8 coarse thread socket head bolts. Les. Quote Link to comment Share on other sites More sharing options...
