Guest diesel_jim Posted July 10, 2007 Share Posted July 10, 2007 I'm building a 110, and want to fit a second fuel tank, as in, one of the under seat top filling military jobbies. i'm sure they're 10 gallons. anyone got a good idea where to get one from? it's a RH one i want. are they still available new? or does anyone have a really good condition second hand one? Mucho gracius. Quote Link to comment Share on other sites More sharing options...
SOA 93 Posted July 10, 2007 Share Posted July 10, 2007 I'm building a 110, and want to fit a second fuel tank, as in, one of the under seat top filling military jobbies.i'm sure they're 10 gallons. anyone got a good idea where to get one from? it's a RH one i want. are they still available new? or does anyone have a really good condition second hand one? Mucho gracius. Your local SPI distributor should be able to get new ones, yes 10 gallons but made in the style of pressed 90/110 ones rather than the original sort. LH and RH are available and they take a 90/110 style filler cap. They also sell the outriggers. Why are you not fitting a 90 tank? If you dont mind me asking Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 10, 2007 Share Posted July 10, 2007 Your local SPI distributor should be able to get new ones, yes 10 gallons but made in the style of pressed 90/110 ones rather than the original sort.LH and RH are available and they take a 90/110 style filler cap. They also sell the outriggers. Why are you not fitting a 90 tank? If you dont mind me asking Cheers for that, i'll give them a shout. why not a 90 tank? because i'm building a 110 SW, and there is nowhere on the side bodywork to cut in the filler spout. it's a shame as i've got a 90 tank on my, err, 90. i suppose i could get the inlet pipe welded up and a new filler bit put in, but it would just be easuer to get a proper top filling tank t hat i can access from under the seat. Quote Link to comment Share on other sites More sharing options...
Wattle Posted July 10, 2007 Share Posted July 10, 2007 Hi I might have a side tank that fits under the drivers seat, it fills from the top. Where abouts are you, I am in North Lincs. Phil Watson Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 10, 2007 Share Posted July 10, 2007 Hi I might have a side tank that fits under the drivers seat, it fills from the top. Where abouts are you, I am in North Lincs.Phil Watson I'm in Swindon, wiltshire, but can organise a courier no problem. what condition is it in? Quote Link to comment Share on other sites More sharing options...
SOA 93 Posted July 11, 2007 Share Posted July 11, 2007 Cheers for that, i'll give them a shout.why not a 90 tank? because i'm building a 110 SW, and there is nowhere on the side bodywork to cut in the filler spout. A few years ago in LRM 'IIRC' one of the scribes put a SW body on a military chassis, the series tanks encroached into the rear footwells a little, I think the crossmember and floor had to be cut and then the tank boxed, are you aware of this? I have a pair of the civvy version of these tanks if you want me to take a measurement I can, if it helps. Andy Quote Link to comment Share on other sites More sharing options...
