Diff seal change
Following the "how to" in the tech archive
seal change
I bought the new seal and did the job on my own.
I know it's the same thing but I took pics while under the LR and I thought
it was a shame not to use them...
So,park the LR on a flat ground.
I had no flat ground around,but I have some flat pieces of wood I use when waxoyling the chassis.
The Cube II is levelled:
Parking brake still to be refitted(...) :rolleyes: so more wood and some bricks to chock the wheels,and drained the diff oil:
No zip tie around to keep the propshaft away so more wood
In the pic the useful propshaft tool I finally bought from Difflock (but it's "made in Japan"!!!Or China,or something like!Go figure...!) <_<
and my long Beta torque wrench (made in Italy though) :D to undo the nylock nut
Here's the old seal and surface rust on the splines :(
First screwdriver I tried was too little.
Back with the biggest one I found.
Pry the old seal out and get oil all over the face :huh:
Make mental note "wear goggles next time" :rolleyes:
Make another note "buy dad a new screwdriver" :mellow:
Clean and degrease before fitting the new seal
Slightly grease the new seal and press it in place.
Went in one side only so a professional tool is needed now.
Find mom's vacuum cleaner and borrow this
Refit flange,nylock nut (didn't find torque values though),propshaft...
and now I'm ready for the next job
:rolleyes:
HTH
