Chris Davies Posted October 18, 2005 Share Posted October 18, 2005 Its nearly MOT time so naturally things are starting to go wrong, this time the indicators not working (any of them) when I try and operate them I get a buzzing noise from what looks like a relay. I can't remember off the top of my head what the terminals are labelled as but there is a 48 and a 48a - there are only 3 wires connected to the 'relay'. So is this a relay? and what info do I need to buy a replacement. Thanks Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted October 18, 2005 Share Posted October 18, 2005 I suspect this is the flasher unit, any motor factors should have one, take it with you to be sure. Quote Link to comment Share on other sites More sharing options...
Chris Davies Posted October 18, 2005 Author Share Posted October 18, 2005 Thanks ltwt1981, that sounds likely, didn't think of the flasher unit, it looked like a relay but didn't have the connections I'd expect to see on a relay. Quote Link to comment Share on other sites More sharing options...
minivin Posted October 18, 2005 Share Posted October 18, 2005 my favourite company on such matters: Vehicle Wiring Products Under this page: Relays You will find the following chart: Terminal reference guide. U.K. Euro. French. Supply X,B,+ 15,49 + Earth -,E 31 31 Ind switch L 49a C, COMM Vehicle w/lamp P C R, Rep Trailer w/lamp C2 but this forum don't do true-text so off to they there website be you!!! Quote Link to comment Share on other sites More sharing options...
Chris Davies Posted October 18, 2005 Author Share Posted October 18, 2005 Thanks all, was indeed the flasher unit - replacement on its way from vehicle wiring products. Cheers Quote Link to comment Share on other sites More sharing options...
