TheRecklessEngineer Posted July 12, 2007 Share Posted July 12, 2007 Hi guys, Got a little problem on a 300 TDi 110 here that has me a little confused... The symptom is a large puff of black smoke on startup - this occurs when the engine is hot or cold. My initial thought was injectors, but after an "Italian tune up" which normally sorts out most injector problems I have seen, there is no improvement. It hasn't been tuned, and doesn't smoke at full load (well, a haze, but no smoke screen) So whaddya you reckon? Bite the bullet and fork out for 4x new injectors? Or is there something I am missing? Quote Link to comment Share on other sites More sharing options...
GBMUD Posted July 12, 2007 Share Posted July 12, 2007 My 200Tdi has always done that. Not running on olive oil are you? Chris Quote Link to comment Share on other sites More sharing options...
Steve King Posted July 12, 2007 Share Posted July 12, 2007 Most diesels give out a puff of black smoke on starting and nearly every Land Rover Tdi lets out a big puff of smoke. I wouldn't worry about it as long as it doesn't belch smoke on the overun when warm. Steve Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted July 12, 2007 Author Share Posted July 12, 2007 Yup, my disco is...but this 110 belongs to the local dive club. They also have another 110 built for desert storm, but never used. V8 on SU's with an R380 behind it - luuuuurvely. First use was 4 years ago. Hmmm...ok, I won't worry then. Was going to tweak the pump for them, but wanted to make sure all was good first. Quote Link to comment Share on other sites More sharing options...
RRX Posted July 12, 2007 Share Posted July 12, 2007 Mine lets out a big cloud of smoke weather hot or cold but runs fine Quote Link to comment Share on other sites More sharing options...
simonb Posted July 12, 2007 Share Posted July 12, 2007 Hi guys,Got a little problem on a 300 TDi 110 here that has me a little confused... The symptom is a large puff of black smoke on startup - this occurs when the engine is hot or cold. My initial thought was injectors, but after an "Italian tune up" which normally sorts out most injector problems I have seen, there is no improvement. It hasn't been tuned, and doesn't smoke at full load (well, a haze, but no smoke screen) So whaddya you reckon? Bite the bullet and fork out for 4x new injectors? Or is there something I am missing? Its normal. When the engine is off, the centrifugal governer in the injector pump sets the fuelling to max rich setting. As the engine starts, the governer starts to operate and winds the fuelling back to the idle run setting. Hence the puff of black smoke caused by the fuelling being at the max rich setting initially. Quote Link to comment Share on other sites More sharing options...
