Outrage Posted October 18, 2005 Share Posted October 18, 2005 Ive rebuilt both the rear tub, seatbox and door cills on my lightweigtht from scratch and ive been daft enough to scrap the originals. Can anyone tell me how the seatbox is secured to the door cills and vertically up the rear (below the door lock thingies) of the door? I was thinking pop rivets, but did the originals use those retaining clips and screws? Thanks all, Quote Link to comment Share on other sites More sharing options...
Mark Posted October 18, 2005 Share Posted October 18, 2005 From memory of doing my IIa it is all done with 1/4 UNF nuts and bolts. I don't think there are any captive ones... will have to check the ltwt when I get in though... Mark Quote Link to comment Share on other sites More sharing options...
tuko Posted October 18, 2005 Share Posted October 18, 2005 Ja, they were bolted into place, for ease of removal, when work was carried out on the trans....... Todd. Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 18, 2005 Share Posted October 18, 2005 IIRC three bolts downwards and two on the vertical (under the door lock thingies) Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 19, 2005 Share Posted October 19, 2005 Yep, Tonk is right - three along and two up, then about 10 along the back. The end ones along the back are a bit of a swine to undo. All 7/16"(11mm is near enough) if original, although you might find that more recent work means they may now be M6 (10mm head) Les. Quote Link to comment Share on other sites More sharing options...
Outrage Posted October 19, 2005 Author Share Posted October 19, 2005 Yep, Tonk is right - three along and two up, then about 10 along the back. The end ones along the back are a bit of a swine to undo. All 7/16"(11mm is near enough) if original, although you might find that more recent work means they may now be M6 (10mm head)Les. Cheers Lads, Glad i asked, got some funny ideas in my head! Still, after having it in bits for 2 years you do tend to forget the simplest details! (you aught to see the box of nuts and bolts i'm left with! ) Quote Link to comment Share on other sites More sharing options...
