mwoodpower Posted July 13, 2007 Share Posted July 13, 2007 i have a 2002 td5 with 170k on the clock, had new head @ 150k, how long do these engines last? and what are the common problems, gear box is noisy any idea of how easy a change, would be diy? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 13, 2007 Share Posted July 13, 2007 Piece of string question - I have seen a Td5 in one of our company vehicles totally u/s at 45k miles while others have similar mileage to yours with no problems. Quote Link to comment Share on other sites More sharing options...
Escape Posted July 16, 2007 Share Posted July 16, 2007 I know a few TD5s with 200k+ miles, without (major) engine work, just the unavoidable replacement alternator, starter... A lot depends on how you drive it. Quote Link to comment Share on other sites More sharing options...
101sean Posted July 16, 2007 Share Posted July 16, 2007 Mines a mere youngster at 92000, no problems apart from oil in the loom cos' previous owner didn't bother with warranty stuff. Gearbox is DIYable, depends on facilities you have as to how difficult it is. You can take Tbox off seperately to make it more manageable. How noisy is it? Quote Link to comment Share on other sites More sharing options...
mwoodpower Posted July 17, 2007 Author Share Posted July 17, 2007 Mines a mere youngster at 92000, no problems apart from oil in the loom cos' previous owner didn't bother with warranty stuff.Gearbox is DIYable, depends on facilities you have as to how difficult it is. You can take Tbox off seperately to make it more manageable. How noisy is it? only quite gear is 4th, dont think there is much life left, changed oil that made it quieter for a week or two, can get a local garage to change for about £250 (labour) is this good value? Quote Link to comment Share on other sites More sharing options...
101sean Posted July 17, 2007 Share Posted July 17, 2007 only quite gear is 4th, dont think there is much life left, changed oil that made it quieter for a week or two, can get a local garage to change for about £250 (labour) is this good value? Not bad, Ashcrofts charge about £400 if you deduct the cost of the box and clutch off their £975 quote. Be prepared to allow for a new flywheel though, early ones were prone to cracking but should be OK on an 02 Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted July 18, 2007 Share Posted July 18, 2007 My 2002 Td5 is chugging well on 118k, gears are whiney (transfer) but the MOD police dont seem to have managed to break it so it must be strong! Quote Link to comment Share on other sites More sharing options...
stobbie Posted July 20, 2007 Share Posted July 20, 2007 My '00 disco td5 has 200000 miles on the clock, almost every mile with a very big trailer. Only thing I've ever replaced is the starter. Even on it's original clutch (which is now getting a noisy bearing). It still doesn't use a single drop of oil. I do have a spare 10000 mile TD5 engine ready, in case my old one dies suddenly, this Disco must keep running.. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted July 21, 2007 Share Posted July 21, 2007 The TD5 doesn't last long when the oil pump chain breaks.... Another superb design feature by LR. I reckon they were about to start the first engine and... 1st Engineer: OK, start her up. 2nd Engineer: Hang on, where's the oil pressure gauge? 3rd Engineer: Where's the oil pump, come to think of it? 1st Engineer: The 4th engineer was supposed to do that. 2nd Engineer: He got run over by a bus a year ago... 3rd Engineer: I have this wonderful idea, how about we .... (to be continued) Quote Link to comment Share on other sites More sharing options...
