tuko Posted October 18, 2005 Share Posted October 18, 2005 Today I removed the Weber carb to trial fit the SU/adapter and to my surprise, I found that there is a reducer under the EGR adapter. The reducer, reduces the bore from 44mm to 40mm, leding into the inlet manifold. Obviously, this reduces performance, so I'm wondering, can I remove it? Is there anybody out there that has done that, or are running with this reducer? The reducer is over 1cm thick, if the carb is closer to the manifold, will there be an issue with over heating in the carb? Opinions/suggestions ? Todd. Quote Link to comment Share on other sites More sharing options...
landi41 Posted October 18, 2005 Share Posted October 18, 2005 Today I removed the Weber carb to trial fit the SU/adapter and to my surprise, I found that there is a reducer under the EGR adapter. The reducer, reduces the bore from 44mm to 40mm, leding into the inlet manifold. Obviously, this reduces performance, so I'm wondering, can I remove it? Is there anybody out there that has done that, or are running with this reducer? The reducer is over 1cm thick, if the carb is closer to the manifold, will there be an issue with over heating in the carb? Opinions/suggestions ? Todd. Todd.....long time since i had a 4 pot Series carb off so i dont recall that opening being smaller........ firstly why not try the carb without the spacer, ( asuming the linkage works) if the carb runs hotter that can only be a good thing for winter secondly i suppose you could machine the adaptor hole to suit.................. Quote Link to comment Share on other sites More sharing options...
Chris Davies Posted October 19, 2005 Share Posted October 19, 2005 Todd, which weber are you running? the twin choke of a 2.5 or the one sometimes found on the 2.25? Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted October 19, 2005 Share Posted October 19, 2005 My 2.25 petrol series III lightweight had that reducer leading to the inlet manifold too, never had any issues, mind you dunno how I would have known if it lacked power! Quote Link to comment Share on other sites More sharing options...
MartinEva Posted October 19, 2005 Share Posted October 19, 2005 Todd, which weber are you running? the twin choke of a 2.5 or the one sometimes found on the 2.25? Chris. Thats the 34ICH single choke kit used to replace the Zenith 36IV. Todd. I suspect you would gain nothing but removing the reducer. The carb is already a 34mm which actually has a 29mm choke. If you want better performance, the 32/36 DGV is the way to go Cheers Martin Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted October 19, 2005 Share Posted October 19, 2005 No help at all re carburetted engines and probably off-topic but ... are you sure it's an EGR adapter? Quote Link to comment Share on other sites More sharing options...
tuko Posted October 20, 2005 Author Share Posted October 20, 2005 No help at all re carburetted engines and probably off-topic but ... are you sure it's an EGR adapter? Ummm..... maybe a PCV valve LOL Todd. Quote Link to comment Share on other sites More sharing options...
