Ex Member Posted July 13, 2007 Share Posted July 13, 2007 Anyone know or has one to measure? I want to get a drain valve before the next oil change. Quote Link to comment Share on other sites More sharing options...
simonb Posted July 13, 2007 Share Posted July 13, 2007 Anyone know or has one to measure?I want to get a drain valve before the next oil change. I suspect, but can't actually confirm, its probably 1/2" BSP which is the same size as the blanking bungs in the top of domestic central heating rads..... Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 14, 2007 Share Posted July 14, 2007 Red, have you seen those oil drainers on Difflock ? I've had one for 3 or 4 years now and it makes oil changes a breeze ! See here Mo Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 16, 2007 Author Share Posted July 16, 2007 I hadn't seen those, but it would be a lot cheaper to get one on this side of the world if I knew the thread size. I usually use Fumoto. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 16, 2007 Author Share Posted July 16, 2007 I suspect, but can't actually confirm, its probably 1/2" BSP which is the same size as the blanking bungs in the top of domestic central heating rads..... Not in my domestic world Quote Link to comment Share on other sites More sharing options...
Puddles Posted July 16, 2007 Share Posted July 16, 2007 tis indeed 1/2" BSP Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 16, 2007 Author Share Posted July 16, 2007 Thanks. I guess I will get a Difflock one then. Damn you Whitworth!!!! Quote Link to comment Share on other sites More sharing options...
simonb Posted July 16, 2007 Share Posted July 16, 2007 Not in my domestic world most of the time, obviously not for the old "classic" cast iron ones or some modern slimline ones... Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 16, 2007 Author Share Posted July 16, 2007 I meant BSP does not exist over here. BSP is a strange British only pipe thread with the crazy never seen Whitworthless thread form.... Rovers are great in that they use every known form of thread ever made in one vehicle, even within one engine. Quote Link to comment Share on other sites More sharing options...
simonb Posted July 16, 2007 Share Posted July 16, 2007 I meant BSP does not exist over here. BSP is a strange British only pipe thread with the crazy never seen Whitworthless thread form.... Rovers are great in that they use every known form of thread ever made in one vehicle, even within one engine. Aah, didn't spot u were over the "other side"... Quote Link to comment Share on other sites More sharing options...
