a frame balljoint
So i've got the a-frame off, but i cant get the ball joint out of the housing. I have tried heat, big hammers, even bigger hammers !
has anybody got any advice as to how to get the joint out ?
Thanks
Oilit
Once the ball joint housing is off, you can normally undo the two 13mm bolts and then bash the old one out. Unless you have a press it's unlikely that you'll successfully fit the new one. My local MOT station lets me use their press to put it in.
You could use the hot housing/freezing cold ball joint method, but it's a bit of a risk.
Les.
Hi,
Glad to hear you got it out. Usually I cut the tabs off under the bolt heads, place ball joint mounting in a good vice, soak in plus gas and knock out. Re- fitting using two long bolts with nuts on and screw down into place.
ATB
Mike
Hi,
ATB
Mike
tried the long bolts, but its just bending the flange !
need a press....ebay me thinks !
 Share
