jameslwt Posted July 15, 2007 Share Posted July 15, 2007 I'll put this on the classified forum as well, but does anyone have a spare drop plate for a defender (I'm assuming it's the standard land rover/dixon bate jobbie) as I've just won a sankey on the bay, and want to be able to mount the nato hitch on another plate so I can quickly switch between that or a normal ball hitch (which I already have on the truck). Cheers James Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted July 15, 2007 Share Posted July 15, 2007 James If you look on the classifieds forum under my name and you'll see I have a complete tow system for sale. You are only down the road from me. Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted July 15, 2007 Share Posted July 15, 2007 I'll put this on the classified forum as well, but does anyone have a spare drop plate for a defender (I'm assuming it's the standard land rover/dixon bate jobbie) as I've just won a sankey on the bay, and want to be able to mount the nato hitch on another plate so I can quickly switch between that or a normal ball hitch (which I already have on the truck).Cheers James Just so you know, You won't need a drop plate to tow a sankey - it's designed to run level with the NATO hitch mounted to the rear x member. Matt Quote Link to comment Share on other sites More sharing options...
jameslwt Posted July 16, 2007 Author Share Posted July 16, 2007 Just so you know, You won't need a drop plate to tow a sankey - it's designed to run level with the NATO hitch mounted to the rear x member. Matt Hi Matt Does that mean I can bolt the nato hitch straight to the rear crossmember, with the original towbar gubbins on top/mounted behind? I want to retain the adjustable towball for when towing normal trailers (standard ball hitch). obviously it's an adjustable height thing. If so, anyone have any ideas what size bolts I need. ?Have got to go a fair way to collect trailer, and nato hitch comes with it, so will probably end up having to attach hitch when I collect trailer, so will try to get bolts beforehand! Cheers James Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted July 16, 2007 Share Posted July 16, 2007 Hi MattDoes that mean I can bolt the nato hitch straight to the rear crossmember, with the original towbar gubbins on top/mounted behind? I want to retain the adjustable towball for when towing normal trailers (standard ball hitch). obviously it's an adjustable height thing. If so, anyone have any ideas what size bolts I need. ?Have got to go a fair way to collect trailer, and nato hitch comes with it, so will probably end up having to attach hitch when I collect trailer, so will try to get bolts beforehand! Cheers James yes you can Quote Link to comment Share on other sites More sharing options...
