copper brake pipe
HoSS
For after market use it is pretty much an industry standard now ……………… I usually have 10m of 3/16 in stock under the bench.
Make sure you get a quality flaring tool as the cheaper items are carp…………
These are very good …………….I have the universal light ………….. but the heavy is also good……
Then theres the de-burring tool and the brake pipe bender ................ all very useful items to have to hand
http://www.automec.co.uk/oakes_tools/oakes_frame_set.html
Ian
My flaring tool was is cheap :hysterical::rtfm:
Les. :)
Indeed, the model that you depict does indeed work extremely well ............. but if its what I think it is, then it will not be replaceable on a like for like basis, unless you find one at an auto jumble ;)
Perhaps I should have said ............ avoid the cheapo, Laser, Sealey and Draper (to name but a few) flaring tools.
Ian
totally agree.
when i was doing the brake pipes on a mates 2dr rangie - i must have binned about 10 lengths of pipe due to having to use a draper flaring tool.
absolutely carp.
ridges and ripples on all the ends, misshapen, burrs and copper flakes..... horrible.
  • 3 weeks later...
