Bumpyride Posted July 20, 2007 Share Posted July 20, 2007 I have been continuing my rebuild abiet a little slow and periodic With both front wheels off, if i A: rotate the drivers side hub, drive is immediately taken up and the prop rotates. B: rotate the passenger side hub then the prop roates a 1/16th approx of a turn and then stops with then drivers wheel then starting to rotate. C: roate the prop the drviers only side rotates. immediately Is this corect - ie all about the driver going to the shaft iwth least resistance? If so then are the resistances i'm seeing correct? Also if i rock the dirvers disk towards and away from me then i get a little movement: Am i right in thinking that this is liely to be the wheel bearing or possibly swivel pins ( or with my liuck both ) comments please Quote Link to comment Share on other sites More sharing options...
