sea daddy Posted July 20, 2007 Share Posted July 20, 2007 I just installed some parabolic springs I received from Atlantic British, forest green color for rear springs and grey for front springs. Once installed, my 79 series 3 LWB santana sits slightly higher on the passenger side. I noticed that the rear springs are marked "N/S" and "O/S". Currently the N/S spring is mounted on the drivers side on the LHD vehicle. Why am I sitting higher on the passenger side? Should I just switch out the rear springs, putting the O/S on the drivers side? Any help is truly appreciated.....calling me a novice would be an overstatement. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 21, 2007 Share Posted July 21, 2007 O/S (off-side) is the drivers side of the vehicle - determined by how you would correctly park - the passenger side being on the Near (closest to the kerb) Side. Off side is Off The Kerb. N/S and O/S refer to the vehicle and not it's position when parked. It looks like you just put the springs on the wrong side - I bet that's a tad annoying Les. Quote Link to comment Share on other sites More sharing options...
sea daddy Posted July 21, 2007 Author Share Posted July 21, 2007 Thanks Les. I just finished changing the springs to the opposite side, sitting pretty! Now on to the next project...... Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 21, 2007 Share Posted July 21, 2007 Now on to the next project...... Putting the engine in the right way round? Les. Quote Link to comment Share on other sites More sharing options...
