Bull Bar Cowboy Posted August 29, 2007 Share Posted August 29, 2007 see the ZF4 pump that comes with the mile marker kit for fitting to the 200tdi in the aircon slot,is that man enough for the job for making the winch fast enough & pull enough like the one on petal? or do i need to throw that TF & use a different pump? Currently got an XP powered 8274 & "may" consider changing sides The ZF 74 is barely adequate for the job of powering the winch ....................but the ZF74 is not the only show stopper in making the winch faster......... the pipework is also too small and the standard MM solenoid valve will only flow 3.5 gals (US)................. For the calcs see my winch build thread here http://forums.lr4x4.com/index.php?showtopic=6087 Ian Quote Link to comment Share on other sites More sharing options...
dollythelw Posted August 29, 2007 Share Posted August 29, 2007 if you want to work out exactly what type of belt to use and the maximum power its capable of transmitting this site is really really handy Fenner Drive Designer hope that helps Quote Link to comment Share on other sites More sharing options...
yella 90 Posted September 1, 2007 Share Posted September 1, 2007 jez where did u get your type r from ? dan Quote Link to comment Share on other sites More sharing options...
