GSDMAN999 Posted July 22, 2007 Share Posted July 22, 2007 Hi and Hello to all A newbie here! I need a drawing of the valve block with the relevant solenoids and which represents each valve. Couldn't find anything like on Rave disk Cheers Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted July 23, 2007 Share Posted July 23, 2007 Go to Rover Renovations site http://www.rover-renovations.com/ and look for the overhaul instructions, they probably contain what you want. Even with the import taxes, it's probably the best place to buy bits as well. This may also be of interest. For reasons which escape me completely it was posted in the International Forum. http://forums.lr4x4.com/index.php?showtopic=15994 The most significant proviso, is that 20 mins is too long for the system to pump up. I can't recall the exact figure on Rave, but it's no-where near 20 minutes. That indicates a new compressor seal / piston ring is required. Cheers. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 24, 2007 Share Posted July 24, 2007 For reasons which escape me completely it was posted in the International Forum. I post all tech threads in the international forum so that the maximum amount of people will read it and hopefully it'll stick in their mind that the information is available in the archive. Filling the reciever seemed to take 20-minutes, but may have been less. I went and got a sandwich and was chatting to the customer - it just seemed that long to me. Les. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted July 24, 2007 Share Posted July 24, 2007 The compressor should fill an empty tank and switch out the pressure switch in about 8mins,20 is far too long and suggests a worn compressor seal - or less likely a leak. Quote Link to comment Share on other sites More sharing options...
