Guest otchie1 Posted July 22, 2007 Share Posted July 22, 2007 Prepping my 110 2.5TD for an imminent clutch job I've found lacey rust where the the floor panels screw into the bottom of the bulkhead. A quick look about the net turned up plenty of S111 footwells that look the part (and are verrrrry cheap....is the same part? Will it fit? Quote Link to comment Share on other sites More sharing options...
western Posted July 22, 2007 Share Posted July 22, 2007 These will fit YRM metal solutions -- footwell Quote Link to comment Share on other sites More sharing options...
Guest otchie1 Posted July 22, 2007 Share Posted July 22, 2007 These will fit YRM metal solutions -- footwell Ta, YRM, of course. Should have thought to check my own bookmarks. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 23, 2007 Share Posted July 23, 2007 If it's just the bottom strip that goes under the edge of the floor plate then it's not necessary to replace the whole footwell. The damaged strip can be cut off and replaced. This is a similar job that I did, but extends further than you need to I think. Les. Quote Link to comment Share on other sites More sharing options...
