Geminidawn Posted July 22, 2007 Share Posted July 22, 2007 Since the tank on the Hybrid was moved from under the seat to the back I now have to cut an access for the fuel in the back panel, so I'm looking for a Defender fuel inlet assembly that I can pop rivet into place. So far no luck, it's not a replacement part I can buy and local scrap yards are hesitant to cut holes in the few Defenders they get in. Quote Link to comment Share on other sites More sharing options...
western Posted July 22, 2007 Share Posted July 22, 2007 not listed in EPC as a seperate part, but yopu maybe able to use the hi-cap pick up version cover fuel filler [inside body] MTC1461 & cowl fuel filller [outside] MTC3569. or if the hole is already in the outer panel you could fold up your own version using suitable alloy sheet or steel sheet. Quote Link to comment Share on other sites More sharing options...
Geminidawn Posted July 22, 2007 Author Share Posted July 22, 2007 if the hole is already in the outer panel you could fold up your own version using suitable alloy sheet or steel sheet. Yeah I thought of that and it looks simple enough to fabricate but time is a luxury I can't afford. There is such a huge list of work to be done on the vehicle already and it all has to be done by yesterday, I was kinda hoping to just pick one up and bolt it into place. Quote Link to comment Share on other sites More sharing options...
western Posted July 22, 2007 Share Posted July 22, 2007 proably have to order the hi-cap bits if you decide to use them, so won't be a quick job. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 23, 2007 Share Posted July 23, 2007 Does it have to be a Defender filler? Wouldn't a series one do the same job? Les. Quote Link to comment Share on other sites More sharing options...
Geminidawn Posted July 23, 2007 Author Share Posted July 23, 2007 Does it have to be a Defender filler? Wouldn't a series one do the same job?Les. Either as long as it will fit. I did find one on an abandoned Series but it was set on the curve of the panel, furthermore the feeder pipe was rusted through. The Defender ones are set on the flat and since the back panels on the Ambulance are flat it would be a better fit also Defenders are more recent so the chances are I'll find one in better condition. Some one once suggested an Aircraft style flush mounted fuel filler cap but I'd prefer something that looks more original. Quote Link to comment Share on other sites More sharing options...
Geminidawn Posted August 3, 2007 Author Share Posted August 3, 2007 Sorted! Thanks to SRB60, PRICELESS! Quote Link to comment Share on other sites More sharing options...
Ex Member Posted August 4, 2007 Share Posted August 4, 2007 One other method I have seen it to run both tank fillers from the original location. See here: http://roverlanders.bc.ca/roverforum/viewtopic.php?t=1739 Quote Link to comment Share on other sites More sharing options...
