range rover speedo
bernie
I have a 1989 Range rover, that has a speedo that malfunctions occasionally, but when i looked for the cable at back of clocks it`s not there, are they electronic, or am i not looking in the right area, ive not looked at gearbox end yet.
If it is electronic (i.e. no speedo cable) check the transducer attached to the transfer box. It's fitted where the speedo cable would normally plug in. These have been known to play up. Also check the connections.
HTH
Ivan
When you say malfunction do you mean the needle drops to zero from time to time whilst in motion?
Almost certainly the square drive cable form the transfer box. Dead easy and cheap to replace.
