bernie Posted July 22, 2007 Share Posted July 22, 2007 I have a 1989 Range rover, that has a speedo that malfunctions occasionally, but when i looked for the cable at back of clocks it`s not there, are they electronic, or am i not looking in the right area, ive not looked at gearbox end yet. Quote Link to comment Share on other sites More sharing options...
Ivan Posted July 23, 2007 Share Posted July 23, 2007 If it is electronic (i.e. no speedo cable) check the transducer attached to the transfer box. It's fitted where the speedo cable would normally plug in. These have been known to play up. Also check the connections. HTH Ivan Quote Link to comment Share on other sites More sharing options...
bishbosh Posted July 26, 2007 Share Posted July 26, 2007 When you say malfunction do you mean the needle drops to zero from time to time whilst in motion? Almost certainly the square drive cable form the transfer box. Dead easy and cheap to replace. Quote Link to comment Share on other sites More sharing options...
