Jon W Posted July 23, 2007 Share Posted July 23, 2007 Can some one send me a picture of the 200tdi air filter set up please. I have put a discovery 200tdi engine in and need to sort the filter out as couldn't find space for the discovery one to fit. Also does anyone have a 200tdi air filter casing for sale or and the brackets if it is likely to fit Cheers Jon Quote Link to comment Share on other sites More sharing options...
bobonacus Posted July 23, 2007 Share Posted July 23, 2007 Here are a couple from my 200tdi converted 90 Quote Link to comment Share on other sites More sharing options...
western Posted July 23, 2007 Share Posted July 23, 2007 these should help, from my retro-fit 200TDi in my '89 110 http://www.steve-parker.co.uk/site.html in their LR mags advert now do a 200Tdi air filter/bracket kit, no idea of the price though. Quote Link to comment Share on other sites More sharing options...
thirstybeast Posted July 23, 2007 Share Posted July 23, 2007 Hi Dont know what age vehicle you have but for me the brackets on the LH wing that hold the heater air intake and coil were ideal for mounting the 200 disco filter brackets. The air filter is 300 TDI because the elements are cheaper. Quote Link to comment Share on other sites More sharing options...
kevin Posted July 23, 2007 Share Posted July 23, 2007 Hi Jon, if your 200tdi is a disco unit you will find you cannot fit the filter housing in its original position as the intercooler pipe will run through that area, i found a length of pipe and a K&N filter is a better job and also makes it run & sound better. Kevin Quote Link to comment Share on other sites More sharing options...
MickStobbs Posted July 24, 2007 Share Posted July 24, 2007 Jon, i did what Kevin said as well,the turbo pipe of my old TD engine and an old K&N (of an old beach buggy project of my mates)in th passanger side inner wing. Anyway,best of luck with the rest of your conversion,its the best mod i ever did....Mick. Quote Link to comment Share on other sites More sharing options...
Puddles Posted July 24, 2007 Share Posted July 24, 2007 I used a 200tdi air filter unit on my conversion and managed to fit it in that corner ok - sits between the wing an the intercooler pipe. it sits quite high up, about as high as you can comfortably get it without it touching the bonnet. the hose to the turbo unit is facing the rad though - this allows it to connect to the turbo easier if its a disco engine as the flexi pipe (you'll have to buy a length of snorkel hose) can sweep down and under the alternator with no tight bends. I just made up a bracket (using the old n/a top rad mounting bracket) bolted to the inner wing so it sticks vertically upwards, then bolted that to the air filter casing with a nice thick bolt - works a treat. Quote Link to comment Share on other sites More sharing options...
Jon W Posted July 24, 2007 Author Share Posted July 24, 2007 Thanks for all the photos and help. Have done the conversion and it is running very well, but running the old petrol airfilter with bits of guttering and want to do the job properly and be able to connect the snorkle up. I just need to find filter housing and a few more bits of pipe work. Cheers Jon Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2007 Share Posted July 24, 2007 ebay would probably be the easiest place to find the bits you need. Quote Link to comment Share on other sites More sharing options...
picpoki Posted April 12, 2010 Share Posted April 12, 2010 Can anybody tell me if air filter from 2.5 petrol is suitable for disco 200tdi conversion? Does it get enough of air? Are the housings the same? I would like to put in K&N air filter but I don`t know if it`ll fit in petrol housing. Thanks D. Quote Link to comment Share on other sites More sharing options...
western Posted April 12, 2010 Share Posted April 12, 2010 different part numbers, the petrol element maybe slightly longer, probably easier to stay with the correct Discovery air filter element. I don't know if the diameter or internal length is the same Quote Link to comment Share on other sites More sharing options...
dwappat Posted April 12, 2010 Share Posted April 12, 2010 Just to add a different way of fitting the filter housing when doing a discovery conversion. (the other pictures I think look like defender 200tdi engines with the raised turbo, rather than disco's low mounted one) Hope this helps Dave Quote Link to comment Share on other sites More sharing options...
picpoki Posted April 12, 2010 Share Posted April 12, 2010 I don`t have disco air filter housing and that is why I`m asking. Will have to make some miles without air filter to see if the engine gets enough air. So if this airbox is too small and I want to get some more power from the engine I need to buy disco airbox... Thanks for help guys. Cheers Quote Link to comment Share on other sites More sharing options...
picpoki Posted April 12, 2010 Share Posted April 12, 2010 Dave, pics are from disco engine. I didn`t change the airbox mounts. Conversions look so easy on RHD Might be seen on this photo Don`t have better pics. Cheers Another Q: Does the plastic cover over the engine head and inlet manifold make any diference about the noise? Quote Link to comment Share on other sites More sharing options...
Smokydiesel Posted April 12, 2010 Share Posted April 12, 2010 Combined the 2,5 NA-filterhousing (upside down) with the 200 TDI housing-lid. The air intake is just underneath the wing. Quote Link to comment Share on other sites More sharing options...
