discosi Posted July 23, 2007 Share Posted July 23, 2007 Help/guidance wanted. I have a 1996 disco, 300tdi, and have suddenly started getting a 'judder' through the vehicle when accelerating. It appears to be intermittent possibly when loading the engine. It proves difficult to pin point but seems fine on initial acceleration and when up to speed but inbetween the 'jubber' starts. The engine seems to be running fine when standing and when increasing the revs, but does seem to be hot (could only just hold onto dip stick as so hot after 2 hour drive) , although the temp gauge does not show it. Any advice as to where to start to look would be much appreciated. steering, wheel bearings, prop shafts? etc. Cheers Quote Link to comment Share on other sites More sharing options...
moose Posted July 23, 2007 Share Posted July 23, 2007 Any advice as to where to start to look would be much appreciated. steering, wheel bearings, prop shafts? etc. my moneys on a front prop JU.... to check the front UJ's jack up a front wheel and rotate the prop looking for play in the joints. Quote Link to comment Share on other sites More sharing options...
Rodewaryer Posted July 25, 2007 Share Posted July 25, 2007 my moneys on a front prop JU....to check the front UJ's jack up a front wheel and rotate the prop looking for play in the joints. While checking under there I'd look at the rear prop shaft U-joint as well. Quote Link to comment Share on other sites More sharing options...
discosi Posted July 25, 2007 Author Share Posted July 25, 2007 my moneys on a front prop JU....to check the front UJ's jack up a front wheel and rotate the prop looking for play in the joints. Thanks for the guide. Have found rear UJ on front prop shot. In process of replacing. Quote Link to comment Share on other sites More sharing options...
