V8CAMEL Posted July 24, 2007 Share Posted July 24, 2007 morning At the weekend i bought a 300tdi auto disco. Used it fine over the weekend and travelled up to birmingham with no problems. total about 250 miles. Last night when i left work it was really sluggish. When driving it struggles past 2000 RPM when not loaded ie neutral it happly revs away. Its as though it is in get you home mode It is a N plate ES. chassis TA any info would be helpful as i dont fancy driving home (140 miles) at 50mph thanks paul Quote Link to comment Share on other sites More sharing options...
q-rover Posted July 24, 2007 Share Posted July 24, 2007 Check air hoses between turbo and intercooler. They have a habit of collapsing internally, so you have to take them off to inspect. Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted July 24, 2007 Author Share Posted July 24, 2007 Check air hoses between turbo and intercooler.They have a habit of collapsing internally, so you have to take them off to inspect. thats what it seems like the one from the turbo to the metal tube seems extremely soft. Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted July 24, 2007 Author Share Posted July 24, 2007 thats what it seems like the one from the turbo to the metal tube seems extremely soft. can someone confirm for me that the following part numbers are the ones i need ESR2912 and esr2913 typical i have some at home but that is 140 miles away so will have to order and pay for some shock horror thanks in advance western paul Quote Link to comment Share on other sites More sharing options...
GBMUD Posted July 24, 2007 Share Posted July 24, 2007 The fuel lift pump could be failing too Paul. Have you tried removing the pipe and pumping the priming lever? Could the fuel filter be blocked? Is there plenty of fuel in it? Chris Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted July 24, 2007 Author Share Posted July 24, 2007 The fuel lift pump could be failing too Paul. Have you tried removing the pipe and pumping the priming lever? Could the fuel filter be blocked? Is there plenty of fuel in it?Chris new fuel filter went on sat afternoon 1/2 tank of fuel had been run on veggie oil and the filter was mank but it ran ok on the veggie oil and ran fine all the way up yesterday morning . When i started it in the work carpark the power was gone. dont think it is the fuel pump as it revs freely when not under load ie to 4-5 k rpm its as though its in get you home mode which when it happened on the freeloader was turbo pipes paul Quote Link to comment Share on other sites More sharing options...
bishbosh Posted July 24, 2007 Share Posted July 24, 2007 I had a Toy pickup in the Caribbean that did this - it was water in the fuel. The fuel filter filled up with water and starved the engine of fuel. Try draining the fuel filter. Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted July 24, 2007 Author Share Posted July 24, 2007 I had a Toy pickup in the Caribbean that did this - it was water in the fuel. The fuel filter filled up with water and starved the engine of fuel.Try draining the fuel filter. will try that tonight ta Quote Link to comment Share on other sites More sharing options...
nickm Posted July 24, 2007 Share Posted July 24, 2007 sounds like fuel filter too me mine runs really flat if i put too much much cooking oil in it Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted July 24, 2007 Author Share Posted July 24, 2007 sounds like fuel filter too memine runs really flat if i put too much much cooking oil in it ok will take it off and check to night paul Quote Link to comment Share on other sites More sharing options...
stripy Posted July 24, 2007 Share Posted July 24, 2007 dont forget to cheak the fuel sediment catcher its at the rear offside just befor the wheel arch behind the chassis, mine was full of carp . Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2007 Share Posted July 24, 2007 can someone confirm for me that the following part numbers are the ones i needESR2912 and esr2913 typical i have some at home but that is 140 miles away so will have to order and pay for some shock horror thanks in advance western paul esr2912 elbow intercooler [ turbo end of steel pipe] esr2913 intercooler hose [forward end [attaches steel pipe to intercooler stub pipe] Quote Link to comment Share on other sites More sharing options...
