gelf Posted October 20, 2005 Share Posted October 20, 2005 just fitted a 2.5 petrol......... just until i have the funds for something better... got a little black fuel pump with it.... should be mounted near the tank or will it ok mounted on the bulk head. did think about putting it in the battery box but then thought what if it leaked and then a spark..... kaaboom graham Quote Link to comment Share on other sites More sharing options...
landi41 Posted October 20, 2005 Share Posted October 20, 2005 just fitted a 2.5 petrol......... just until i have the funds for something better...got a little black fuel pump with it.... should be mounted near the tank or will it ok mounted on the bulk head. did think about putting it in the battery box but then thought what if it leaked and then a spark..... kaaboom graham I,m guessing this is going into a Series as the Defender fuel pumps are in the tank........ Last year i temporarily mounted an electric fuel pump on my 110 in the rear fender box, i have seen the Series ones mounted on the frame near the gas tank........ and i don't see why a bulkhead mount would not be OK In fact thats probably the easiest fit.............. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 20, 2005 Share Posted October 20, 2005 We've had 3 and all the pumps were also mounted in the tank, a combined pump/pickup/gauge thing IIRC I agree - in the battery box prob not a good idea! Quote Link to comment Share on other sites More sharing options...
Mehetabel Posted October 20, 2005 Share Posted October 20, 2005 On my 109" SW the fuel pump is on the frame rail under the driver [right side] under where the tank would be if it were not a SW. cheers John Quote Link to comment Share on other sites More sharing options...
Diff Posted October 20, 2005 Share Posted October 20, 2005 Hi Gelf, most electric fuel pumps are better at 'pushing fuel up hill' than they are at 'sucking fuel uphill'. So it would be best somewhere no higher than the top of the chassis rail. If you mount it higher up on the bulkhead in the engine bay, you 'may' have problems. Hope this helps, Regards, Diff Quote Link to comment Share on other sites More sharing options...
