russ1 Posted July 25, 2007 Share Posted July 25, 2007 Hello people Right where do i start. The other month i was playing around it the landy and i needed to change it to low box. But know matter what i did the lever was moving to the correct place but was still in hi range. i got home pulled the drivers seat out, removed the 6 bolts on the top ov the transfer box and checked the grub screw witch was still tight ( this was the cause ov the problem last time) After that i dropped the oil and removed the sump. looking into the box gold syncro that slides to engage hi or low range wasn't moving at all when the selector was moved. it seems as if there is sum sort ov fork that should move the syncro but mine seems to have lifted up away from the syncro. i got a small bit ov welding wire and hooked it on to the fork and pulled it back on to the syncro and it then worked fine but a day after i tryed to engage low box again and nothing happened so guessing the fork has lifted up again. Does anyone know what could be causing this problem ( is the fork broken ) Any ideas how to fix it or is it time for a new one ( hope not cause bank manger is starting to hate my landy ) Looking at the box its self it seems new ish, still has the stickers on etc. so its abit ov a pain!!!!!!!!!! Thanks again Quote Link to comment Share on other sites More sharing options...
ashtrans Posted July 25, 2007 Share Posted July 25, 2007 Hi, if the shaft is moving but the fork isn't, it can only be this grub screw, Quote Link to comment Share on other sites More sharing options...
russ1 Posted July 25, 2007 Author Share Posted July 25, 2007 Hi,if the shaft is moving but the fork isn't, it can only be this grub screw, Is there any way i can get into it to tighten it? Thanks dave Quote Link to comment Share on other sites More sharing options...
russ1 Posted July 25, 2007 Author Share Posted July 25, 2007 Also if that was not tight would the fork be able to lift up away from the syncro? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 25, 2007 Share Posted July 25, 2007 The rod would prevent the fork from lifting up. The rod should only be able to move backwards and forwards through holes in the case casting. If the fork is definitely moving up and down either it's busted off the rod, or there's a problem with the rod or casting. With the cover off - engage and disengage repeatedly and see what's actually happening in there. Les. Quote Link to comment Share on other sites More sharing options...
russ1 Posted July 25, 2007 Author Share Posted July 25, 2007 its as if it is pivoting on the shaft. with abit luck i will be able to get into the grub screw and make sure its ok before i end up having to replace the box. Quote Link to comment Share on other sites More sharing options...
russ1 Posted July 27, 2007 Author Share Posted July 27, 2007 any1 any idea how to get in to check the grub screw???? Thanks Quote Link to comment Share on other sites More sharing options...
