Color code and rim size
Smokydiesel
Hi all,
Two quick questions that probably have been asked a 1000 times before (sorry…) but here I go….
I have a 1969 Series IIa 88’, will 90/110/Defender rims fit ?
My Series has a grey colour, I need to spray two new doortops, does anyone know the exact colour-code or description ?
Thanks !
Edwin.
wot size wheel nuts do u have?
if 23mm then def rims wont fit
if 27mm then they will
old stuff is 9/16 stud, modern stuff is 16mm stud
New Rims should fit on older studs shouldn't they? I have 2 SIII rims on my IIa, and I thought the 90/110 rims were the same as SIII?
Given that the wheels are hubcentric they should be ok???
Mark
