SiWhite Posted July 26, 2007 Share Posted July 26, 2007 Does anyone have access to a 200Tdi Discovery turbo that's not attached to the manifold? I'm after a pattern of studs and the exhaust 'hole' in the middle to get an adaptor made for my new variable nozzle turbo. Could someone draw a sketch for me so I can take it to the local engineering firm? Many thanks! Quote Link to comment Share on other sites More sharing options...
Baldrick Posted July 26, 2007 Share Posted July 26, 2007 You could buy the metal gasket that goes in between - probably better than a drawing...... Quote Link to comment Share on other sites More sharing options...
SiWhite Posted July 26, 2007 Author Share Posted July 26, 2007 Cool - didn't realise there was one! Anyone got a part number? Ralph? Quote Link to comment Share on other sites More sharing options...
western Posted July 26, 2007 Share Posted July 26, 2007 Cool - didn't realise there was one! Anyone got a part number? Ralph? That's because there isn't one, no gasket listed between the turbo & manifold on a Discovery 200Tdi engine only the manifold to the cylinder head gasket. Quote Link to comment Share on other sites More sharing options...
SiWhite Posted July 26, 2007 Author Share Posted July 26, 2007 Ah.....Back to Plan A.....Anyone got one they can measure / sketch? Quote Link to comment Share on other sites More sharing options...
SOA 93 Posted July 26, 2007 Share Posted July 26, 2007 Ah.....Back to Plan A.....Anyone got one they can measure / sketch? I have one off the manifold, can measure etc, or I could trace it for you then scan or Fax. Andy Quote Link to comment Share on other sites More sharing options...
SOA 93 Posted July 29, 2007 Share Posted July 29, 2007 That's because there isn't one,no gasket listed between the turbo & manifold on a Discovery 200Tdi engine only the manifold to the cylinder head gasket. On my 200Tdi Disco there is indeed no gasket, however, yesterday while looking for something else in the garage I came across the remains of top-end overhaul gasket kit, it contained both a gasket for the turbo to the manifold and a gasket for the turbo to cast downpipe, this was a pattern gasket set, maybe the Defender 200TDi has a gasket as I assume the set I had would have been a universal set. Andy Quote Link to comment Share on other sites More sharing options...
western Posted July 29, 2007 Share Posted July 29, 2007 Defender 200TDi engine certainly does have a metal gasket between the turbo casing & manifold, but it's different to the Discovery variant of the 200TDi, so no help to Si. Quote Link to comment Share on other sites More sharing options...
RRX Posted July 29, 2007 Share Posted July 29, 2007 is it a normal 4 bolt fitting on the 200 tdi? Quote Link to comment Share on other sites More sharing options...
SOA 93 Posted July 29, 2007 Share Posted July 29, 2007 Defender 200TDi engine certainly does have a metal gasket between the turbo casing & manifold, but it's different to the Discovery variant of the 200TDi, so no help to Si. Already emailed SiWhite with a trace of the turbo flange + dimensions, but that was before I found the gaskets, I've just been and checked and there is indeed two turbo gaskets in the set I have, one matches the disco turbo perfectly, the other matches the studs but it has a radiused square hole in the middle as opposed to the Disco hole which is circular........ The turbo is one I swapped with selectcase and it has a definate mark where a gasket has been previously. Quote Link to comment Share on other sites More sharing options...
western Posted July 29, 2007 Share Posted July 29, 2007 Just found 1 of each in my garage too. Defender 200Tdi turbo gasket on left, Discovery 200Tdi turbo gasket on right Si you can have the Disco one if you PM your postal address. Quote Link to comment Share on other sites More sharing options...
SOA 93 Posted July 29, 2007 Share Posted July 29, 2007 Just found 1 of each in my garage too.Defender 200Tdi turbo gasket on left, Discovery 200Tdi turbo gasket on right Si you can have the Disco one if you PM your postal address. Blimey that was quick!! There both Disco 200TDi gaskets, the one on the right is the turbo outlet to the cast downpipe. Quote Link to comment Share on other sites More sharing options...
western Posted July 29, 2007 Share Posted July 29, 2007 guess who picked up the wrong rectangular one, here's all 3 top left is Defender turbo to manifold gasket the other 2 for Discovery [200Tdi engines on both vehicles] Quote Link to comment Share on other sites More sharing options...
