Francis Posted July 27, 2007 Share Posted July 27, 2007 Hi. I did an oil change on my 110 V8. Changed the filter. Now, oil has started to leak out of a wierd bolt about 1 cm above the oil filter. It has a metal thing sticking out of it that looks like it should have a wire attached (there is a second one of these close by, that has a wire running to it). I will take a pic tomorrow and post it, need to know how to stop this leak, it's pi**ing oil each time I turn it on. Quote Link to comment Share on other sites More sharing options...
Gromit Posted July 28, 2007 Share Posted July 28, 2007 is it in this diagram? Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted July 28, 2007 Share Posted July 28, 2007 Don't worry about it - If it stops leaking then you know to put some more in! Quote Link to comment Share on other sites More sharing options...
western Posted July 28, 2007 Share Posted July 28, 2007 sounds like the oil prssure switch is the one with the wire on it & either oil prssure gauge transmitter or oil temp transmitter is the other one. Quote Link to comment Share on other sites More sharing options...
Francis Posted July 29, 2007 Author Share Posted July 29, 2007 It's number 9. I was told to get something to block the top of it, so I have filled it with epozy metal putty. No more leak. And oil temps still reporting on the dial. Thanks for the diagram! Also. She is black now. I need to update my picture. Quote Link to comment Share on other sites More sharing options...
western Posted July 29, 2007 Share Posted July 29, 2007 It's number 9. I was told to get something to block the top of it, so I have filled it with epozy metal putty. No more leak. And oil temps still reporting on the dial.Thanks for the diagram! Also. She is black now. I need to update my picture. thats the oil pressure switch that operates the red oil light on the dash warning light panel, it should be working & have a white/brown tracer wire attached to the spade terminal. it will leak again, get a new switch when you can, it will only take a few minutes to change. part number is above. Quote Link to comment Share on other sites More sharing options...
