Guest diesel_jim Posted July 29, 2007 Share Posted July 29, 2007 I'm just getting some work done on my HD 110 chassis, and i tried fitting the R380 gearbox crossmember (as it had the V8/Td5 type previously). anyway, some of the bolt holes lined up, some didn't, which i thought was strange. crawling under my 300Tdi 90, all the bolt holes are used, so i was wondering if there is a different (special?) R380 gearbox crossmember for 110's? my microcat only shows ANR6386 for 90 or 110, nothing to differentiate between the two Could anyone who has a 300Tdi 110 with R380 have a look for me and see which bolts are used? here's what mine looks like: as you can see, the lower bolt hole (where the red circle is) doesn't line up with the hole in the crossmember (due to the 110 chassis being deeper than that of a 90 one... on my 90, both top and bottom holes line up) on this one, the two red holes line up OK, but the blue one doesn't. not a problem, i can drill that through. thanks all. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 30, 2007 Share Posted July 30, 2007 Anyone? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 30, 2007 Share Posted July 30, 2007 I'd look at mine but it's dripping with sh*t at the moment after my "commute" and I've got work clothes on... Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 30, 2007 Share Posted July 30, 2007 No probs!! Quote Link to comment Share on other sites More sharing options...
western Posted July 30, 2007 Share Posted July 30, 2007 although my 110 has a R380 fitted, don't think pics will be of much use as it still has the original round LT77 x-member under the box, as mines a '89 vehicle. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted July 30, 2007 Share Posted July 30, 2007 I've just been out under mine.... The grass is WET I can't see much because of the gearbox. I'll have another crawl under tomorrow. mike Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted July 30, 2007 Share Posted July 30, 2007 I've just been out under mine.... The grass is WET I can't see much because of the gearbox. I'll have another crawl under tomorrow.mike Might be easier to look at by lifting out the access panel under the centre seat. No good me looking, TD & LT-77. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted July 31, 2007 Share Posted July 31, 2007 Might be easier to look at by lifting out the access panel under the centre seat.No good me looking, TD & LT-77. You could be right but there is no chance of that happening. The Defender is half packed ready to go to the shipping company on Thursday.... Quote Link to comment Share on other sites More sharing options...
mmgemini Posted July 31, 2007 Share Posted July 31, 2007 Nice fresh warm morning here Jim. I've been under. ALL holes are used. Second picture. Top hole circled red. FYI That's where my battery earth lead is. mike Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 31, 2007 Share Posted July 31, 2007 Thanks Mike. i don't suppose there is any chance of you (or anyone else) measuring how "tall" the side plate of the outrigger is? (the flat piece that sits onto the side of the chassis rail) (red arrows on the the attached pic) i'm thinking that mine must be for a 90 or disco, and hence it's not as tall. or 110's have a second set of holes for 300Tdi's? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 31, 2007 Share Posted July 31, 2007 Not that this will be much help but on the 109 I used Range Rover gearbox mounts that bolt to the chassis, and then the plain square RR x-member. I understand some (defenders?) the box is supported by the x-member? Quote Link to comment Share on other sites More sharing options...
mmgemini Posted July 31, 2007 Share Posted July 31, 2007 Weigh up Jim. That crossmember is different on mine. I'll go and struggle with a camera. The measurement you wanted is 7 11/16" as near as I can make it. The hole at the top of the chassis isn't used...... The crossmember is traingulated at the front as well at the back. Polygone shape ??? mike Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 31, 2007 Share Posted July 31, 2007 Weigh up Jim.That crossmember is different on mine. I'll go and struggle with a camera. The measurement you wanted is 7 11/16" as near as I can make it. The hole at the top of the chassis isn't used...... The crossmember is traingulated at the front as well at the back. Polygone shape ??? mike Hmm... mine is that sort of shape, and about that height as well. when you say "the hole at the top of the chassis isn't used" do you mean neitehr of the holes line up with each other? what about the holes at the front/top of the crossmember? sorry for all the Q's! Quote Link to comment Share on other sites More sharing options...
mmgemini Posted July 31, 2007 Share Posted July 31, 2007 Quick chassis question you said Jim Right oh then..... They say a picture is worth a thousand words.... Is it ?? LOL Left side of chassis inside. I've chalked the crossmember at chassis. There is another bolt above the one you can see as in your picture Front of crossmember left side of chassis. The top bolt is impossible to see here. It's hidden behind the gearbox mounting. I only found it by feeling with my fingers.... mike Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 31, 2007 Share Posted July 31, 2007 AHA!!! Sussed it!!!! I'm using the wrong crossmember. i just compared it to my 90 (300Tdi) one, and they're different. the 90 one looks like it'll work OK., cheers Mike, the pics were a great help. Jamie Quote Link to comment Share on other sites More sharing options...
mmgemini Posted July 31, 2007 Share Posted July 31, 2007 Your welcome Jim Can I finish packing now mike Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 31, 2007 Share Posted July 31, 2007 actually, just one more........ nah, only kidding mate! Thanks again. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted July 31, 2007 Share Posted July 31, 2007 You'd better ber quick if you have to. There's only tomorrow [Wednesday ] for me to look as the car goes Thursday...... mike Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 31, 2007 Share Posted July 31, 2007 where are you going? Quote Link to comment Share on other sites More sharing options...
mmgemini Posted August 1, 2007 Share Posted August 1, 2007 Namibia, Botswana, South Africa........ We hope to be back in time to go to the Donington show..... Have a look here.. http://www.landroveraddict.com/smf/index.php?topic=358612.0 Plenty for you to read mike Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted August 1, 2007 Share Posted August 1, 2007 You jammy git! i'd love to do that..... one day... when my 110 is finished..... oh yes!!! Quote Link to comment Share on other sites More sharing options...
