s2hotdog Posted October 21, 2005 Share Posted October 21, 2005 As it says will it without to many complications? Cheers Steve Quote Link to comment Share on other sites More sharing options...
LR90 Posted October 21, 2005 Share Posted October 21, 2005 As it says will it without to many complications?Cheers Steve Moglite is probably your man for this. He fitted salisbury's f&r on the Ibex. Quote Link to comment Share on other sites More sharing options...
Diff Posted October 21, 2005 Share Posted October 21, 2005 Yes it will fit, but the existing propshaft will be too long as the nose of the salisbury is longer. You will have to have a custom length propshaft made. All the locating mountings will be the same, though make sure you use the lower spring locating discs from the 90 axle as the 110 has larger diameter rear springs. Be aware that the Salisbury axle has slightly less ground clearance under the diff than the rover axle. Hope this helps, Regards, Diff Quote Link to comment Share on other sites More sharing options...
s2hotdog Posted October 21, 2005 Author Share Posted October 21, 2005 Diff thanks for that ................. think I'll wait till a disco one comes up Cheers Steve Quote Link to comment Share on other sites More sharing options...
