clutch pipes
Pat
 Share
Can describe it if that's any good..................
Clutch master on bulkhead, Rigid steel pipe to a bracket on the side of the drivers side footwell - close to where the throttle rod comes through. then flexi pipe from there to a bracket that is held to the fuel lift pump bracket and retained by two of the bolts that hold it to the engine block. Then steel pipe again from there, around the back of the engine and held in two places by 'P' clips on two of the flywheel housing bolts. The pipe then goes down on the passenger side behind the starter motor bolts and angles slightly inboard to the clutch slave cylinder close to the chassis.
Les.
 Share
