Birder Posted August 1, 2007 Share Posted August 1, 2007 Auto electrician informed me that engine oil found its way into my TD5's engine harness, Apparently designer fault? Has anyone experienced same problem? How do I fix it? Quote Link to comment Share on other sites More sharing options...
JSG Posted August 1, 2007 Share Posted August 1, 2007 It is a known problem with IIRC a warranty fix of changing part of the loom. If you do a search on here you should find a few threads on it. Quote Link to comment Share on other sites More sharing options...
jules Posted August 1, 2007 Share Posted August 1, 2007 Renew the parts which are contaminated or it will leed to a fried ECU. Mine had it. The looms are expensive Quote Link to comment Share on other sites More sharing options...
SteveG Posted August 4, 2007 Share Posted August 4, 2007 You need to replace the Injector loom, IIRC it's about 40 pounds Cheers Steve Quote Link to comment Share on other sites More sharing options...
