michael calvert Posted August 2, 2007 Share Posted August 2, 2007 where the oil cooler pipes connect to the filter housing there appears to be two fitting (one on each pipe) male to male so the cooler pipe can connect into it, (the cooler has a female end and so does the filter housing) anyone no the part numbers for these? ps its for a 300 tdi! cheers Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted August 2, 2007 Share Posted August 2, 2007 On the Tdi's i've had, the oil pipes were male and they screwed into a female casting on the filter housing. do you mean on the radiator? mine had a male-male threaded bit (and they're different threads for Tdi radiators and TurboD rads! the thread for the "pipe" is the same) Quote Link to comment Share on other sites More sharing options...
michael calvert Posted August 2, 2007 Author Share Posted August 2, 2007 On the Tdi's i've had, the oil pipes were male and they screwed into a female casting on the filter housing.do you mean on the radiator? mine had a male-male threaded bit (and they're different threads for Tdi radiators and TurboD rads! the thread for the "pipe" is the same) no on the oil cooler at filter end, think its got confused due to the bl**dy thing having braided cooler hoses which have the female end! perhaps im looking for the unfindable? Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted August 2, 2007 Share Posted August 2, 2007 All my microcat shows is this: the "waxstat adaptor" Quote Link to comment Share on other sites More sharing options...
michael calvert Posted August 2, 2007 Author Share Posted August 2, 2007 All my microcat shows is this:the "waxstat adaptor" its the bit the screws in that isnt shown on there, would you mind having a look seein if anything is shown on the pipe schematics? Quote Link to comment Share on other sites More sharing options...
western Posted August 2, 2007 Share Posted August 2, 2007 oil filter head adaptors are NRC8618 only used on 2.5 petrol,2,5n/a diesel,2.5TD & 200Tdi engines, not listed for 300Tdi as the correct hose screw directly into the oil filter head. Quote Link to comment Share on other sites More sharing options...
michael calvert Posted August 6, 2007 Author Share Posted August 6, 2007 oil filter head adaptors are NRC8618 only used on 2.5 petrol,2,5n/a diesel,2.5TD & 200Tdi engines, not listed for 300Tdi as the correct hose screw directly into the oil filter head. i see. what is the thread on those pipes, perhaps i could get an adaptor to suit the standard pipe thread and my braided hose thread - if only Quote Link to comment Share on other sites More sharing options...
western Posted August 6, 2007 Share Posted August 6, 2007 Sorry Micheal, haven't a clue of the thread size/type, try your local mobile Hydraulic repair man [Pirtek or similar] he should be able to help. Quote Link to comment Share on other sites More sharing options...
