bazza Posted August 3, 2007 Share Posted August 3, 2007 fitted a 200tdi disco gearbox and transfer case (LT230) to my RRC, now the speedo dont work! its got the electronic type sender with a short cable, is the cable a diffefrent size for the drive? it came out of a BW trans case. have checked power to the sender/transducer thingy thats OK. any way to check for a output signal? Cheers Baz Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted August 4, 2007 Share Posted August 4, 2007 Output signal is a square wave (ie. on/off pulse) - if you pop the speed transducer out and turn it by hand or move the vehicle slowly you can see it on an ordinary multimeter. Quote Link to comment Share on other sites More sharing options...
bazza Posted August 5, 2007 Author Share Posted August 5, 2007 Output signal is a square wave (ie. on/off pulse) - if you pop the speed transducer out and turn it by hand or move the vehicle slowly you can see it on an ordinary multimeter. OK cheers, will check it out Baz Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 6, 2007 Share Posted August 6, 2007 Same happened to me - speed was dodgy after gearbox change and finally died. The square drive shaft was badly tounded off so I swapped the short cable for a new one (£10 ish) and all was well. Quote Link to comment Share on other sites More sharing options...
