flatback90 Posted August 4, 2007 Share Posted August 4, 2007 simple question lads the new series i have has a fairey od but the sticker has gone of the lever is it lever forward for the od to work or back? Quote Link to comment Share on other sites More sharing options...
rtbarton Posted August 4, 2007 Share Posted August 4, 2007 IIRC it's forwards to engage, but it shouldn't be too difficult to find out. Drive along at 30 mph, move the lever (clutch in &c&C) and if the revs go down for the same speed you're now in OD, if they increase you've just changed out of OD. NB there is a neutral position between forwards & back so don't get caught out when the car won't move! Quote Link to comment Share on other sites More sharing options...
02GF74 Posted August 6, 2007 Share Posted August 6, 2007 3 position forrward - o/d in middle - neutral back - o/d out You fit the knob so the you can read the writing the right way up. Quote Link to comment Share on other sites More sharing options...
rtbarton Posted August 6, 2007 Share Posted August 6, 2007 .....You fit the knob so the you can read the writing the right way up. ...... Who'd have thought that Quote Link to comment Share on other sites More sharing options...
western Posted August 6, 2007 Share Posted August 6, 2007 I thought the positions were engraved into the lever top, if so a tin of white paint & a pencil brush would restore it. or use tippex correction fluid. Quote Link to comment Share on other sites More sharing options...
flatback90 Posted August 6, 2007 Author Share Posted August 6, 2007 its not got the engraved knob lads its some type of sticker thats all worn away and i never had aseries with one before. also i presume its ep90 that you put in? Quote Link to comment Share on other sites More sharing options...
rtbarton Posted August 6, 2007 Share Posted August 6, 2007 its not got the engraved knob lads its some type of sticker thats all worn away and i never had aseries with one before. also i presume its ep90 that you put in? EP90 GL4 is the correct oil. The filler cap incorporates a dipstick Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted August 6, 2007 Share Posted August 6, 2007 The early ones had a flat top knob with a sticker to put on after fitting. Quote Link to comment Share on other sites More sharing options...
flatback90 Posted August 6, 2007 Author Share Posted August 6, 2007 The early ones had a flat top knob with a sticker to put on after fitting. thanks lads! Quote Link to comment Share on other sites More sharing options...
