Guest WALFY Posted August 7, 2007 Share Posted August 7, 2007 I'm running my first tank of biodiesel and it don't half pong. I know you can get all sorts of smelly stuff for your fuel over the pond but is there any thing this side to take away the smell? I could get fed up fairly quickly or do you just get used to it? Quote Link to comment Share on other sites More sharing options...
GBMUD Posted August 7, 2007 Share Posted August 7, 2007 You get used to it. Chris Quote Link to comment Share on other sites More sharing options...
peter and hi two minders Posted August 7, 2007 Share Posted August 7, 2007 if it's your first tank full it probably also burning all the cr*p out of your engine (veg oil is a great cleaner of engines and fuel systems ), mine did for the first 500mls or so now its just a faint chip shop smell. Also carry a spare filter as the veg will clean all the crud from the fuel lines and tank clogging the filter, should be ok after the 1st filter change. Quote Link to comment Share on other sites More sharing options...
Guest weeble Posted August 8, 2007 Share Posted August 8, 2007 I'm running my first tank of biodiesel and it don't half pong. I know you can get all sorts of smelly stuff for your fuel over the pond but is there any thing this side to take away the smell?I could get fed up fairly quickly or do you just get used to it? Come on Walfy. Your not really running Bio Diesel are you. Your just using this as an excuse to cover up your part time job in the local chippy arn`t you. Quote Link to comment Share on other sites More sharing options...
stumpy2268 Posted August 8, 2007 Share Posted August 8, 2007 Come on Walfy.Your not really running Bio Diesel are you. Your just using this as an excuse to cover up your part time job in the local chippy arn`t you. It won't be long before he starts building a vapour truck too :D Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted August 8, 2007 Share Posted August 8, 2007 It won't be long before he starts building a vapour truck too :D Aid Are you insinuating that chip shop owners talk a good car but then can't produce the goods :D :D . Any one in particular? He hasn't had much grief lately so might as well start some ;) Quote Link to comment Share on other sites More sharing options...
JST Posted August 9, 2007 Share Posted August 9, 2007 errrr Puggy they want you here cant see why he hasn't replied, its no like he out building his truck Quote Link to comment Share on other sites More sharing options...
