Bumpyride Posted August 7, 2007 Share Posted August 7, 2007 evening guys Just wanted to check what grease people are using, need to do the hub bearings and then all the grease nipples on prop shafts, ball joints etc. Do you use a standard one or different types dependant onn location? Quote Link to comment Share on other sites More sharing options...
western Posted August 7, 2007 Share Posted August 7, 2007 good old Castrol LM grease will be fine for all those parts Quote Link to comment Share on other sites More sharing options...
Bumpyride Posted August 8, 2007 Author Share Posted August 8, 2007 cheers for that, didn't fancy the craddocks over priced one shot stuff Quote Link to comment Share on other sites More sharing options...
Coastcard Posted August 8, 2007 Share Posted August 8, 2007 cheers for that, didn't fancy the craddocks over priced one shot stuff The one shot stuff is designed for swivel housings, instead of EP90. You want 'proper' grease for the bits you are talking about. Quote Link to comment Share on other sites More sharing options...
western Posted August 8, 2007 Share Posted August 8, 2007 cheers for that, didn't fancy the craddocks over priced one shot stuff you can use EP90 in the front swivels or the later 'one shot' stuff, Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 8, 2007 Share Posted August 8, 2007 I use JCB grease - it's damned good stuff (and a pretty shade of blue ) Les. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted August 8, 2007 Share Posted August 8, 2007 If you add some Wynns Charge to your grease it makes it a lot better.... About a desert spoon into a tin, well plastic container, stir well. mike Quote Link to comment Share on other sites More sharing options...
Gromit Posted August 8, 2007 Share Posted August 8, 2007 If you add some Wynns Charge to your grease it makes it a lot better.... ..and what is that when it's at home? Quote Link to comment Share on other sites More sharing options...
Br00n1e Posted August 8, 2007 Share Posted August 8, 2007 http://www.halfords.com/webapp/wcs/stores/...n__topcategory_ http://www.wynns.net/technical-info/materi...ety-data-sheets Quote Link to comment Share on other sites More sharing options...
Bumpyride Posted August 8, 2007 Author Share Posted August 8, 2007 Am i right in thinking that you mean Wynns Additives - Wynns Super Charge For Oil 425ml have yuo seen good effects? Quote Link to comment Share on other sites More sharing options...
mmgemini Posted August 8, 2007 Share Posted August 8, 2007 Am i right in thinking that you mean Wynns Additives - Wynns Super Charge For Oil 425ml have yuo seen good effects? I first used Wynns Charge in the late 1970's and early 1980's. I was rallying a Hillman Imp. I was knocking front wheel bearings out every event. I mentioned that to the Wynns rep. He gave me some Charge. That stopped me buying bearings every 200 miles. I didn't have any more bearing problems after useing Charge. I keep that grease for my own use only and add Charge to new tins/tubs when I buy new. mike Quote Link to comment Share on other sites More sharing options...
