slihp Posted August 7, 2007 Share Posted August 7, 2007 could some one tell me where i can find this. i thought it was in the engine bay but cant seem to identify it. Quote Link to comment Share on other sites More sharing options...
western Posted August 7, 2007 Share Posted August 7, 2007 on right hand rear chassis rail side face near the rear wheel location Quote Link to comment Share on other sites More sharing options...
davie Posted August 7, 2007 Share Posted August 7, 2007 Just made me remember a ? i was going to ask........ Recently bought a defender also and spent a while finding the fuel filter - next thought was how to remove it for changing? Maybe a silly question but worth asking before i go breaking something expensive Quote Link to comment Share on other sites More sharing options...
slihp Posted August 7, 2007 Author Share Posted August 7, 2007 Got it western, thought that may be it. have so much to learn, not enough time . Dave check this link out. page 256 onwards deals with the fuel system Quote Link to comment Share on other sites More sharing options...
western Posted August 7, 2007 Share Posted August 7, 2007 Got it western, thought that may be it. have so much to learn, not enough time . Dave check this link out. page 256 onwards deals with the fuel system happy to help Quote Link to comment Share on other sites More sharing options...
Gromit Posted August 8, 2007 Share Posted August 8, 2007 Recently bought a defender also and spent a while finding the fuel filter - next thought was how to remove it for changing?Maybe a silly question but worth asking before i go breaking something expensive Which engine? Ralph is talking about the sedimenter, which is on the rear chassis rail, though it's not fitted to all vehicles. The fuel filter is under the bonnet, bolted to the right of the bulkhead (left as you look into the engine) Changing is just a matter of unscrewing and replacing it. You can drain it first, for a slightly less mucky job. Partially undo the bleed screw on the top of the housing. Unscrew the drain plug from the bottom of the filter and drain into a coke bottle or similar. Then replace the filter as normal. It doesn't have to be done up too tight. Tighten the bleed screw. If you have a 200tdi, just crank it till it starts. It's cough a bit till the filter is full again. Check the filter isn't leaking. Don't know about other engines. (Edited to add: TD5 eh? I'll get me coat ) Quote Link to comment Share on other sites More sharing options...
western Posted August 8, 2007 Share Posted August 8, 2007 Gromit -- Edited to add: TD5 eh? I'll get me coat shut the door on the way, never know who just wander in Quote Link to comment Share on other sites More sharing options...
slihp Posted August 8, 2007 Author Share Posted August 8, 2007 although a thourgh explination gromit But prompts a further question. I take it i change this in more or less the same way? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 8, 2007 Share Posted August 8, 2007 Yes, unscrew old one, unscrew water sensor from bottom, fit water sensor to new filter, screw on new filter. Done. Quote Link to comment Share on other sites More sharing options...
slihp Posted August 8, 2007 Author Share Posted August 8, 2007 so i dont need to drain fuel or anything like that? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 8, 2007 Share Posted August 8, 2007 no just be careful when you take the filter off - hold a 2 litre ice cream tub or something underneath it to catch any spillage once you refit the filter, press the pedal right to the floor and release immediately, do this 5 times and the engine management light on the dash should start flashing and the fuel pump will do an on-off-on-off purge cycle lasting for a few minutes, once the light stops flashing press the pedal to the floor and crank till it starts, this carries out the purge to remove any air from the system, the fuel pump might wail a bit but should quieten down after a bit of a run once all the air is out of the fuel system HTH Quote Link to comment Share on other sites More sharing options...
slihp Posted August 8, 2007 Author Share Posted August 8, 2007 ah i see, once you refit the filter, press the pedal right to the floor and release immediately, do this 5 times and the engine management light on the dash should start flashing so you do this with the key out and engine managment takes care of the rest Quote Link to comment Share on other sites More sharing options...
western Posted August 8, 2007 Share Posted August 8, 2007 you'll need the key in switched to the first position to get the warning lights to come on. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 8, 2007 Share Posted August 8, 2007 you'll need the key in switched to the first position to get the warning lights to come on. sorry yes as Ralph says ignition in the on position Quote Link to comment Share on other sites More sharing options...
slihp Posted August 8, 2007 Author Share Posted August 8, 2007 excellent info chaps. all noted Quote Link to comment Share on other sites More sharing options...
slihp Posted August 10, 2007 Author Share Posted August 10, 2007 just got my EPC, cant seem to find the part number for the filter. dose anyone know it (td5 90) Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 10, 2007 Share Posted August 10, 2007 ESR4686 fits all Td5s Defender and Discovery Quote Link to comment Share on other sites More sharing options...
western Posted August 10, 2007 Share Posted August 10, 2007 it's listed under sedimentor diesel Td5 in fuel & emission systems/ fuel eaporation & loss Quote Link to comment Share on other sites More sharing options...
slihp Posted August 10, 2007 Author Share Posted August 10, 2007 got it, i wasnt seeing it originaly i was filtering for defenders. took the filter off and could find it. Quote Link to comment Share on other sites More sharing options...
