Door pillar tops
Coastcard
I've only ever heard of complete pillars - the only other part is right at the bottom where the bulkhead bolt goes through.
The main section of the pillar goes from the curve at the top all the way to the bottom - level with the flat part of the footwell.
Les.
Slightly off topic, but still in the body panel area, has anyone any idea where I could source an A pillar for a Classic Range Rover ? - other than cutting one off a scrapper.
The only panel available appears to be the lower section where the door hinges bolt on.
Apologies if I appear to be hijacking your post :)
Guest WALFY
Buy a 90.
