Manxey Posted August 9, 2007 Share Posted August 9, 2007 Hi All, Does anyone know how to mount an air con pump onto a 200tdi Defender engine? I know where it supposed to go, but im not sure how to do it. I did a search and found someone who was fitting a york compressor, but not an air con pump. And help would be appreciated! Thanks Jon Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted August 9, 2007 Share Posted August 9, 2007 Do you have the brackets that come with the compressor (item 4)? Also are you putting the rest of the AC stuff in? Quote Link to comment Share on other sites More sharing options...
Manxey Posted August 9, 2007 Author Share Posted August 9, 2007 Hi There, No im not putting the rest of the Air con kit in.. I dont have the mounting bracket.. But my timing case is a defender 200 one.. It is different to the one shown in your pictures... Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted August 9, 2007 Share Posted August 9, 2007 My 200 used to have the cast mouting "lugs" but no holes in them. i drilled them so that i could mount a second alternator. just mark the center of the 4 lugs accuratelyl, then drill down them and run a tap in there. you'll eventually need to use a blind tap to get thread to the bottom of the hole. M10 IIRC. Quote Link to comment Share on other sites More sharing options...
western Posted August 9, 2007 Share Posted August 9, 2007 (edited) you'll need to centre mark/drill/thread the 4 cast post on the timing case as D_J has said ^^^^^ the parts you need are below Edited August 9, 2007 by western diagram added Quote Link to comment Share on other sites More sharing options...
Manxey Posted August 9, 2007 Author Share Posted August 9, 2007 you'll need to centre mark/drill/thread the 4 cast post on the timing case as D_J has said ^^^^^the parts you need are below Thanks for that! Really helpful! Can anyone tell me where the mounting lugs are? A picture would be handy, i assume they are between the injector pump and the block on the timing case. I found two of them i think, but they have bolts going through them which hold the timing cover to the timing case. Is this right? Thanks very much Jon Quote Link to comment Share on other sites More sharing options...
western Posted August 10, 2007 Share Posted August 10, 2007 IIRC the air cond pump bracket is attached to these 4 loactions marked by a red cross in my picture below Quote Link to comment Share on other sites More sharing options...
western Posted August 10, 2007 Share Posted August 10, 2007 Do you have the brackets that come with the compressor (item 4)?Also are you putting the rest of the AC stuff in? thiose show the 300Tdi belt routing & location Quote Link to comment Share on other sites More sharing options...
Manxey Posted August 12, 2007 Author Share Posted August 12, 2007 thiose show the 300Tdi belt routing & location Hmmmm, those bits are quite hard to find.. So i guess its back to making my own! lol Quote Link to comment Share on other sites More sharing options...
Ben Spray Posted February 4, 2008 Share Posted February 4, 2008 Hi all I want to do this on my 200tdi as well, I have the defender version of the engine as well. Amongst my parts somewhere I have a air con pump and brackets that came off a discovery 200tdi engine (was going to be fitted to my discovery 200tdi engined 101fc but the location of the gear linkage brackets means I will have to custom make the brackets for that) So question does anyone know if these will fit the defender engine and if so how the belts would need to be routed? Cheers Ben Quote Link to comment Share on other sites More sharing options...
