Cat_J Posted April 18, 2008 Share Posted April 18, 2008 Scotian, you gave me a scare! Being the nerd I am I dashed off and looked up the official Landy 110 2.5Tdi pressures again. They are 28 front (1.93 bar) and 48 rear (3.309 bar) - and they're the same loaded / at speed / whatever.I know, I know - that seems ridiculously high (on the back). What can I tell you? I ran the back tyres on a lower pressure for a while and my mpg dived. Maybe I'm doing my sums wrong? Here's how I work it out. I just filled up today (74.5 litres) after 524 miles (on the Defender clock), which means I used 16.39 gallons (74.5 litres divided by 4.546) , giving an mpg of 31.97. Of course everything's gone to pot now as I've bought a 1991 J plate 110 CSW 200Tdi with big fat tyres. I filled it up t'other day and discovered the seams on the tank leak like nobody's business. I'm hoping that's the reason I only got 430-ish miles on the tank. It's going in for a plastic tank on Wednesday. ...anyone interested in my 200Tdi hard top at £2,000? You're correct in your sums but I though it was supposed to be 40 on the back. I've always had 28 on the front. Quote Link to comment Share on other sites More sharing options...
Landy 90 Hybrid Posted April 18, 2008 Share Posted April 18, 2008 I get around 15mpg with mine, that was taking it quite gently and an RTV trial. In the grand scheme of things I guess not too bad considering she is a 3.5 V8. If caning it, she is down to single figures Jonathan Quote Link to comment Share on other sites More sharing options...
wormey Posted April 18, 2008 Share Posted April 18, 2008 I have a 1996 110 CSW 300Tdi, does about 27mpg, when towing the snail about 21 mpg. No roof rack, has snorkel and cooper stt tyres Quote Link to comment Share on other sites More sharing options...
bpman Posted April 18, 2008 Share Posted April 18, 2008 hi GBMUD, I have a 110 td5 XS and I used to get 31ish on a run, however I have just upgraded the gears in the transfer box to the discovery gear ratios (see ashcrofts web site) and I'm hoping to get 35+. So far I have done 200 miles from a full tank and it's just under the 3/4 mark.. l'll update the post when I've run the whole tank. Steve, Devizes, Wiltshire Quote Link to comment Share on other sites More sharing options...
JST Posted April 18, 2008 Share Posted April 18, 2008 Hi Steve, i would be interested to know how you get on with these. i looked at going this route but decided on an overdrive in the end as towing alot in Hilly Devon i didnt think the 1.2 gears would be upto it as well as the def ones. Do you tow much with yours or mainly A road cruising? Quote Link to comment Share on other sites More sharing options...
bpman Posted April 19, 2008 Share Posted April 19, 2008 hi James Funny, I was really interested in the GKN's but there's lots of -ve feedback re their reliability when towing.. I tow a 2 tonne trailer 2-3 times a month and when fully laden, and there is an incline, I start in low ratio, then "slide" into high ratio when rolling, day-to-day its just got much longer legs, even my wife noticed! However, the main difference is the noise reduction, is that the same for the GKN? cheers Steve Quote Link to comment Share on other sites More sharing options...
