BLACK CAB Posted August 10, 2007 Share Posted August 10, 2007 Somebody here must have done this – what fits on to an early 200 TDI (pre 93) hub? Is it possible to fit later type vented disc calipers STC1266/7 in place of RTC5572/3 earlier solid disc calipers? The later mounting bolts are FTC3375 M12 x 35mm the earlier ones are AFU1031; I assume these are imperial but I have not measured them, dose any one know the dia & thread type? Or would the centre spacer and longer assembly bolts from a junk vented caliper fit between the two halves of a good earlier type solid disc caliper? are the threads in the halves different from early to late type? Thanks Rod Quote Link to comment Share on other sites More sharing options...
white90 Posted August 10, 2007 Share Posted August 10, 2007 later bolts are definatley metric I'd just fit new decent quality pads and genuine discs and save the expense for the extra performance you'll get do you have a Disc braked rear axle fitted? Quote Link to comment Share on other sites More sharing options...
BLACK CAB Posted August 10, 2007 Author Share Posted August 10, 2007 No......... not fitted a disc braked rear axle yet, I am just collecting all the parts and will do the whole thing at the same time. The Existing front calipers have been rebuilt, new pistons etc and fitted with EBC Green pads. Also replaced the hoses with braided stainless. Is there much in the way of improved performance with the rear disc's? other than no drums to fill up with muddy water. Quote Link to comment Share on other sites More sharing options...
western Posted August 10, 2007 Share Posted August 10, 2007 Yes, the later vented calipers will fit, just use the existing bolts to attach to hub. the non vented caliper half bolts won't be long enough 7 wrong thread to convert your existing calipers. still collecting bits for my rear brake conversion to disc, need to find some 90/110 front hubs, disc's & backplates. Quote Link to comment Share on other sites More sharing options...
white90 Posted August 10, 2007 Share Posted August 10, 2007 Ralph JST has a front axle minus the diff with all the bits you may need Quote Link to comment Share on other sites More sharing options...
western Posted August 10, 2007 Share Posted August 10, 2007 RalphJST has a front axle minus the diff with all the bits you may need Cheers, I'll drop him a PM Quote Link to comment Share on other sites More sharing options...
Litch Posted August 11, 2007 Share Posted August 11, 2007 I just bought a spacer kit when I converted my 90 to vented discs, I had rebuilt the calipers & fitted braided hoses only a year or so before and just fancied the vented items so the spacer kit was the easiest option for me. Quote Link to comment Share on other sites More sharing options...
Henry Webster Posted August 11, 2007 Share Posted August 11, 2007 I would vouch that you don't need to go vented apart from for the pose value. I've got solid discs on the front of the Discovery racer and suffer no fade problems (apart from when I've failed to bed the pads in properly, which happened on the first stage of the Scottish Hillrally.) What there is on the front of the racer is the larger 110 calipers. I used EBC green stuff all round. Regular heavy breaking from 80+ mph doesn't cause any problems. H Quote Link to comment Share on other sites More sharing options...
western Posted August 11, 2007 Share Posted August 11, 2007 Glad I swapped to vented front brakes, going down Porlock hill 1 in 4 very steep with a trailer mine still get quite warm by the time we've reached the bottom. Quote Link to comment Share on other sites More sharing options...
