chrisoleary Posted August 11, 2007 Share Posted August 11, 2007 Anyone know the size of these bolts or where I can get them? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 12, 2007 Share Posted August 12, 2007 Do you mean the two that hold the top to the bottom? Mine are studs and nuts. I bought 4 from Bearmach a couple of years ago when I bought my door tops. Les. Quote Link to comment Share on other sites More sharing options...
02GF74 Posted August 13, 2007 Share Posted August 13, 2007 as far as I can tell, these are studs welded to the tops as ^^^^ says. I reckon they are some UNF size; and from memory the nut is 11/16 AF so assuming it is standard sized nut, the bolt diamater can be derived from that info. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 13, 2007 Share Posted August 13, 2007 Alloy door tops have screwed in studs. Steel tops have them welded 02. Les. Quote Link to comment Share on other sites More sharing options...
Gremlin Posted August 14, 2007 Share Posted August 14, 2007 Mine are metric and they have studs installed, M10 i belive. Grem Quote Link to comment Share on other sites More sharing options...
rtbarton Posted August 14, 2007 Share Posted August 14, 2007 The studs are stepped, UNF in Series vehicles, metric in later ones. IIRC 3/8 and 5/16 or M10/M8. This is a drawing of the ones I used to have made Quote Link to comment Share on other sites More sharing options...
chrisoleary Posted August 14, 2007 Author Share Posted August 14, 2007 Thanks guys but I think I now have a part number. Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted August 19, 2007 Share Posted August 19, 2007 If the captive nut in the door (one of the two that holds the door top on) is no longer captive can they be 'got to' from the top? The stud in the diagram above just rotates and this indicates to me that the captive nut has broken free of its anchor.. Its a Mil door top, but assume they are same construction apart from the glass... Also one of the retaining strips for the glass seems to be missing at top and the glass vibrates, can I get series spares for these ? Called craddocks and they were not able to help? Quote Link to comment Share on other sites More sharing options...
