smudge Posted August 11, 2007 Share Posted August 11, 2007 had my air con recharged about 2 months ago, anyway today when i had it on full blast i was gettin bits of what felt like wate coming out, and also a cpl of bits of what felt like ice, is this normal.? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 11, 2007 Share Posted August 11, 2007 Could be just moisture that collected in the system, run it for a while with the heater fan on full but the a/c switched off then try it again, this will allow the evaporator to dry out completely, what I believe happens is that if you have the a/c on when the humidity is high the moisture can freeze onto the evaporator and then melts when the car is sitting giving dampness in the system which can also produce nasty smells I usually run my D2 a/c on "economy" when not needed for just this reason as otherwise I find that you get a blast of damp air when you first start the engine which mists the windows up then you do need the a/c to clear it! Quote Link to comment Share on other sites More sharing options...
smudge Posted August 12, 2007 Author Share Posted August 12, 2007 well done what you suggested but still lots of moisture still coming out of the vents aswell as bits of what feeel like ice Quote Link to comment Share on other sites More sharing options...
