Aldri Tdi Posted August 13, 2007 Share Posted August 13, 2007 Hi All I have recently experienced a metal grinding sound when turning coming from the front drivers side wheel (swivel ball) I took off the wheel and the track rod...no problems with the latter...The grinding noise however comes from the drivers side swivelball if I turn sharply..it sounds like metal grinding (Cluck CLuck noise)..With the wheel off, and taking the disks on a 9 to 3 o'clock grip and moving it in a left and right steer position the grind continues... I inspected the oil level in the swivel ball...and found just a minuscule amount of grease so my guess is that a swivel ball bearing seased...or it could be a CV joint that went? Could an expert please assist me? thanks a million in advance A Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 13, 2007 Share Posted August 13, 2007 If the grease/oil in the swivel housing is low then it could affect the top swivel bearing and/or the CV joint. The only way you are going to know for sure is to strip it down and take a look. Swivel pin bearing wear is identified by pushing/pulling the wheel in the 12 and 6 o-clock positions. What vehicle/axle have you got? Les. Quote Link to comment Share on other sites More sharing options...
