Orgasmic Farmer Posted August 14, 2007 Share Posted August 14, 2007 Anyone know where the engine number is to be found on a 200 tdi (Disco) have had a good look but its nowhere obvious cheers mark Quote Link to comment Share on other sites More sharing options...
nickm Posted August 14, 2007 Share Posted August 14, 2007 Anyone know where the engine number is to be found on a 200 tdi (Disco) have had a good look but its nowhere obviouscheers mark not sure but think its beside the exhaust manifold could be wrong tho Quote Link to comment Share on other sites More sharing options...
mmgemini Posted August 14, 2007 Share Posted August 14, 2007 Right side of engine at the front on the top face of the block. Sort of behind the injection pump. mike Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 14, 2007 Share Posted August 14, 2007 It's been filed off! Les. Quote Link to comment Share on other sites More sharing options...
ciderman Posted August 14, 2007 Share Posted August 14, 2007 I guess it will be if he ever finds it Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted August 14, 2007 Author Share Posted August 14, 2007 :D cheeky buggers well I still haven't found it so I guess someone else has filed it off before me. Is is on a plate or is it cast into the block/stamped in? Will have another look Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted August 14, 2007 Author Share Posted August 14, 2007 found this on LRO forum search "Looking from the front of the car its on the left hand side front of the block running in line with the injector pump and under number 1 injector on the block stamped downover and usually highlighted with white paint. " Will just go check Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted August 14, 2007 Author Share Posted August 14, 2007 Well I had to remove the aircon pump and 16 years of oil deposits and there it was in all its glory! Cheers for all the hints Mark Quote Link to comment Share on other sites More sharing options...
