Gromit Posted August 14, 2007 Share Posted August 14, 2007 My fuel line from the tank is 12mm O.D What bore is it likely to be? I'm guessing 8mm, but want to be sure before I start ordering bits. I'm also assuming that it's OK to T into the fuel line to take fuel to my ebby? Cheers, Quote Link to comment Share on other sites More sharing options...
western Posted August 14, 2007 Share Posted August 14, 2007 8MM bore standard diesel fuel line IIRC, don't fit it give it to me Quote Link to comment Share on other sites More sharing options...
Gromit Posted August 14, 2007 Author Share Posted August 14, 2007 8MM bore standard diesel fuel line IIRC, don't fit it give it to me Thanks Ralph. It spent a year in my shed. Has now spent 6 months mounted, but not connected, in the truck. If I gave it to you, I'd be loosing 18months of work Don't worry, I'll tell you all how lovely and toasty I am over the winter, so you won't feel left out. (hope it works after all that ) Quote Link to comment Share on other sites More sharing options...
western Posted August 14, 2007 Share Posted August 14, 2007 Gromit --If I gave it to you, I'd be loosing 18months of work been looking to get one for longer than that, my mates got one, wonder if he's gonna sell it now, more likelt fit it to his new 56 110DC. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 14, 2007 Share Posted August 14, 2007 Rubber fuel line is always 2mm wall thickness. Les. Quote Link to comment Share on other sites More sharing options...
dreadnought110 Posted August 14, 2007 Share Posted August 14, 2007 My night heater's been performing spot on for years timer set for 6:00am come out at 6:30 lovely and warm no frost Remote start the land rover with the heated seats on and i'am sorted!!!! B) B) Quote Link to comment Share on other sites More sharing options...
Br00n1e Posted August 14, 2007 Share Posted August 14, 2007 tee into fuel line was how we fitted them into the mini buses Quote Link to comment Share on other sites More sharing options...
headhunter Posted August 15, 2007 Share Posted August 15, 2007 Gromit Let me know how you get on as I am in the same position! Ebby fitted (for some months) but not yet connected. Mine is fitted under the offside second row seat on the same side as the fuel line running to the front. Just working up to cutting the fuel line and inserting the tee. Western I will be down in Helford with my 110 at the end of the month, how close are you th there? John Quote Link to comment Share on other sites More sharing options...
Gromit Posted August 15, 2007 Author Share Posted August 15, 2007 GromitLet me know how you get on as I am in the same position! Ebby fitted (for some months) but not yet connected. Mine is fitted under the offside second row seat on the same side as the fuel line running to the front. Mine is mounted nearside second row; same side a fuel and power. Unfortunately I've been off in the mud without covering the fuel feed nipple, so will probably have to strip and clean it up. I've just ordered a slew of bits from VWP, so I'll photo the whole thing and post it up. Planning on T-ing into the fuel line at the highest point of chassis rail, just over the rear wheel, as there's already a junction there. Don't know where to mount the pump yet, maybe inboard side of the chassis rail, between the tank and the ebby. Also not sure about routing cabling to the battery box and dash for the rheostat yet. Will probably do down, and forward on the outside of the truck. If you any ideas, I'd appreciate it before I start Quote Link to comment Share on other sites More sharing options...
western Posted August 15, 2007 Share Posted August 15, 2007 WesternI will be down in Helford with my 110 at the end of the month, how close are you th there? John PM reply sent Quote Link to comment Share on other sites More sharing options...
headhunter Posted August 16, 2007 Share Posted August 16, 2007 Mine is mounted nearside second row; same side a fuel and power. Unfortunately I've been off in the mud without covering the fuel feed nipple, so will probably have to strip and clean it up. I've just ordered a slew of bits from VWP, so I'll photo the whole thing and post it up. Planning on T-ing into the fuel line at the highest point of chassis rail, just over the rear wheel, as there's already a junction there. Don't know where to mount the pump yet, maybe inboard side of the chassis rail, between the tank and the ebby. Also not sure about routing cabling to the battery box and dash for the rheostat yet. Will probably do down, and forward on the outside of the truck. If you any ideas, I'd appreciate it before I start I too will probably route control cables to dash via the underside. As I have several other cables to run, (ARB Compressor, air line compressor gauge tube [pump and tank behind second row seats] and power to both) I plan to run a conduit or two, perhaps some 25mm blue waterpipe, cable tied high up along the chassis. As for the Ebby pump I plan to mount it inside a small plastic box (electrical IP 55 standard about 120mm x 90mm x70mm) fixed to a convenient chassis rail. Remember the pump has to be set at an slight angle. John Quote Link to comment Share on other sites More sharing options...
