seat base
Pat
Is the series seat base ethe same as the defender ones at least as far as the transmission tunnel is concerned. Basically i have a td5 bulkhead which at present has no mods to the transmission tunnel area. I was wondering if i could fit a defender transmission cover while using the defender bulkhead but retaining the series seat base. Any ideas??
I believe they are different. The series type has a flat top on it, whereas the defender is more curved. I don't think you can just swap them over, but people on here have fitted alternative gearboxes to series vehicles and would have had to either make or modify the transmission tunnel. I think both Fridge and Tonk have butchered carefully modified theirs. :D
Les.
