smo Posted August 16, 2007 Share Posted August 16, 2007 Does anyone have a schematic for a TD5 fuel system as i have a bunch of badly colour coded pipes, but neither the pump or the filter are coded to match so i need to sort them out! Quote Link to comment Share on other sites More sharing options...
Petergg Posted August 16, 2007 Share Posted August 16, 2007 Does anyone have a schematic for a TD5 fuel system as i have a bunch of badly colour coded pipes, but neither the pump or the filter are coded to match so i need to sort them out! This might help on pump of a td5 2001 90. Fuel pump Peter Quote Link to comment Share on other sites More sharing options...
smo Posted August 16, 2007 Author Share Posted August 16, 2007 It does, but i also need the filter bit too!! Quote Link to comment Share on other sites More sharing options...
Petergg Posted August 16, 2007 Share Posted August 16, 2007 The left hand pipe from pump is air bleed and goes to the front left of filter. The second left High pressure feed goes to the top of pressure regulator. The 3rd from left is low pressure feed and goes to the left rear of filter. The right hand pipe low pressure return goes to front right of filter. The return from fuel cooler goes to the rear right of filter. HTH Peter Quote Link to comment Share on other sites More sharing options...
smo Posted August 16, 2007 Author Share Posted August 16, 2007 Thanks Peter Quote Link to comment Share on other sites More sharing options...
