BadBob Posted August 17, 2007 Share Posted August 17, 2007 Hi does anybody know if 200 TDI exhaust will fit a 300TDI both 90,s Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted August 17, 2007 Share Posted August 17, 2007 Rear sections should be able to be made to fit, but the downpipes are different... the 300 has a "triangle" shaped flange that bolts to the manifold, the 200's use a large clamp to, err, clamp the pipe to the manifold. Quote Link to comment Share on other sites More sharing options...
BadBob Posted August 17, 2007 Author Share Posted August 17, 2007 Rear sections should be able to be made to fit, but the downpipes are different...the 300 has a "triangle" shaped flange that bolts to the manifold, the 200's use a large clamp to, err, clamp the pipe to the manifold. That's a shame but thanks for info Quote Link to comment Share on other sites More sharing options...
